Author Topic: Preservation of a 68 Camaro  (Read 238527 times)
Re: Preservation of a 68 Camaro
« Reply #435 on: June 17, 2024, 12:43:09 PM »
Photos 882 - 883 - GM U stamping on the original springs
« Reply #436 on: June 17, 2024, 12:44:36 PM »
Photos 884 - 886 - One of the springs after preserving and one of the perches.
« Reply #437 on: June 17, 2024, 12:46:11 PM »
Photos 887 - 888 - Perch bolted and # "20" stamping.
« Reply #438 on: June 17, 2024, 12:47:59 PM »
Photos 889 -891 - Drivers spring installed.  Ignore the finger prints from the gloves.  You will also note off to the side you will see I also installed new (actually used but still flexable vs the originals had dry-rotted) rocker "drain flappers" (technical term)
« Reply #439 on: June 17, 2024, 12:49:34 PM »
Photos 892 - 894 - Passenger side
« Reply #440 on: June 17, 2024, 12:51:13 PM »
Photo 895 - After and the springs are wiped down and a wrap until I get the diff installed and suspension loaded before I tighten the bushings.
« Reply #441 on: June 18, 2024, 11:56:52 AM »
These photos are of the initial teardown.  As you can see the 40 plus year old gear oil had failed.  Current plan is to reuse the carrier which I believe might be the original to the car (can not verify) but since the speedo cable was apparently routed the non muncie way I can route the cable (which I still have CA) and assuming the car had a speedo adapter it would reach and have no issues.  You can also see a wear pattern where the cable rubbed the firewall.
Photos 896 - 898 - Initial tear down
« Reply #442 on: June 18, 2024, 11:58:28 AM »
Photos 899 - 900 - Brakes, lines and dirt daubers
« Reply #443 on: June 18, 2024, 12:03:12 PM »
One thing I failed to mention previously was that I will be swapping gear ratios to a 4.56 as I plan to run a 28" tire and I will need this little small block in the rpms fairly quick or at least that is the intent.  Of course new bearings, seals, brakes and an overall clean up will be the following steps to come.
Photos 901 - 903 - Axle, carrier & pinion
« Reply #444 on: June 18, 2024, 12:05:51 PM »
Photo 904 - Pumpkin wiped out, caps, shims, pin and bolt are clean.  I will be using an aluminum diff cover I snagged from a buddy which I shared in a previous post.
« Reply #445 on: June 20, 2024, 12:23:31 PM »
Up next was the removal of the pinion nut & pinion as well as removing the carrier & axle bearings and said seals.  Also adding the axle stamping & casting date.
Photos 905 - 907 - Pinion removed & axle stamp & diff casting date (appears to be C 2X 8
« Reply #446 on: June 20, 2024, 12:25:11 PM »
Photos 908 - 910 - Old axle bearings removed and new bearings and seals installed.  Also added a shot of the inside of the tubes.  Very clean once the grease was removed.
« Reply #447 on: June 20, 2024, 12:28:00 PM »
Last for today was the removal of the pinion races (Not pictured) and the "new" gear set.  GM dated 10/65 & 11/65 ring & pinion.  Hopefully up next will be the "derustification" of the housing and the installation of the carrier bearings and start to setup the pinion depth etc.  Once that is finished I will set up the backlash and get a wear pattern.
Photos 911 - 913 - GM 3862527 Ring & GM 3862515 pinion
« Reply #448 on: June 24, 2024, 01:59:18 PM »
Drug out the ole evaporust and setup a quickie bath for the diff.  Slow going process at this point before I get back into reassembly.
Photos 914 - 915 - Evaporust bath
« Reply #449 on: June 24, 2024, 02:03:03 PM »
I also starting the cleaning and preserving process of other diff components.
Here is a photo from above for comparison on the brake parts.
Photos 916 - 917 - Some of the brake springs, levers & diff cover bolts, etc.
