Author Topic: Preservation of a 68 Camaro  (Read 155494 times)
Re: Preservation of a 68 Camaro
« Reply #300 on: April 06, 2023, 10:46:49 AM »
Photo 612 - Rear seat
« Reply #301 on: April 06, 2023, 04:53:04 PM »
Here was my solution since I liked the Yenko placement but did not want to drill or mount it to the dash:
« Reply #302 on: April 06, 2023, 05:00:13 PM »
But, that is if you changed your mind about it being on the column.
On a separate note, for getting deeper scratches out of glass, have you ever wet sanded them with a really fine grit of sand paper? I was going to try this, but I was curious if anyone had success doing so.
« Reply #303 on: April 10, 2023, 03:07:37 PM »
Previously removed the steering column for clean up and turns out the lower bearing was trash so it'll get a disassembly, clean and new lower and since they do not sell the bearing for the upper and since it is staked into the aluminum housing it would be a possible issue but thankfully the upper bearing on mine was good just needed repacking with grease.  Lower bearing was ordered from Ground Up (ss396.com).
Photo 613 - 616 - column removed and disassembled  and of the column decal
« Reply #304 on: April 10, 2023, 03:10:37 PM »
Photos 617 - 620 - Paint markings on inner tube etc.
« Reply #305 on: April 10, 2023, 03:17:30 PM »
Photos 621 - 623 - Main shaft
« Reply #306 on: April 10, 2023, 03:18:45 PM »
Photos 624 - 626 - Main shaft cont.
« Reply #307 on: April 10, 2023, 03:22:22 PM »
Photos 627 - 629 - Tolerance ring & spring before and after
« Reply #308 on: April 10, 2023, 03:23:37 PM »
Photos 630 - 632 - Lower bearing compared to new replacement
« Reply #309 on: April 10, 2023, 03:28:35 PM »
Photos 633 - 634 - Lock plate
« Reply #310 on: April 10, 2023, 03:30:42 PM »
Photos 635 - 637 - Upper bearing before and after cleaning
« Reply #311 on: April 10, 2023, 03:34:23 PM »
Photos 638 - 639 - Mid cup after cleaning but before evapo
« Reply #312 on: April 10, 2023, 03:35:32 PM »
Photos 640 - 641 - Lower cup after cleaning but before evapo
« Reply #313 on: April 10, 2023, 03:37:51 PM »
Photos 642 - 643 - Cover
« Reply #314 on: April 10, 2023, 03:39:37 PM »
Photos 644 - 646 - Inner tube after soaking
