Last night I spent a few hours working on removing the black overspray off the top of the cowl and tulip areas. Word of advice, if you still have any MEK make sure you have whatever you are working on in a well ventilated area as you are gonna burn some brain cells.. I almost felt a buzz afterward and I had fans going in the garage. Either way it worked sorta well but I am going to try oven cleaner next. If you have any experience and success with spray bomb removal chime in as I am open to suggestions.
Photo 211 - Pass tulip before removal
Photo 212 - After a few attempts at removal
Photo 213 - Plug removal showing original white for the white out for the stripes
Photo 214 - Upper cowl after a few passes with MEK and a scotchbrite pad and a few with 800 grit paper.
Photo 215 - Fan shroud after cleaning. There was a ton of overspray on it and I still see spots I missed but I needed to "tap out" for the night and called it for now. Will show done done photos once I'm done done.. lol
