Author Topic: Spatter Paint  (Read 38577 times)
Re: Spatter Paint
« Reply #15 on: November 09, 2007, 07:16:09 PM »
John Z.  Does you car with the houdstooth trunk mat have a rectangular sound deadening tar type material mat glued on the trunk floor where the trunk floor starts to slope up to go over the rear axle?  If it does, was the mat applied before or after the spatter paint?  I have a 68 deluxe interior car that has the sound deadening mat but at one point in its life the trunk was resprayed and so was the mat.  I am restoring the trunk but don't know if the mat gets covered with the spatter paint.  Thanks for the help.
Yes, it has the deadener mat, and it's not spatter-painted; the deadener mat was applied in the Fisher Trim Shop, after paint.
bbd564
Re: Spatter Paint
« Reply #16 on: November 10, 2007, 01:26:56 AM »
JphnZ.  Thank you very much for the information, the help is greatly appreciated.
Dave69x33
Re: Spatter Paint
« Reply #17 on: November 17, 2007, 06:25:34 PM »
When I restored my 69Z back in 1995 - 2000, Risk's First Gen had some GM NOS "touch-up" splatter paint.  I used this because at that time, no one had formulated correct spatter paint.  I need to touch mine up but do not have any paint left!!  Attached are few picks.
Mine looks a bit lighter in color than John Z's, but given the mix in the can vs. that sprayed at the assy plant, I suspected differences.
PS: Does anyone sell correct rear seat dividers for rear fold down seats? I have send originals that are black with a tar-like paint on them.
Dave69x33
Re: Spatter Paint
« Reply #18 on: November 17, 2007, 06:33:33 PM »
Here is one more pic with a little more detail of the color....
JohnZ - would you mind posting a few more pics showing the splatter paint spray pattern from different views about your trunk?
Re: Spatter Paint
« Reply #19 on: November 18, 2007, 04:22:23 PM »
Here are three more photos of the trunk area.
Bjv69ss
Re: Spatter Paint
« Reply #20 on: November 18, 2007, 11:04:56 PM »
What got the gray spatter and what got the turquoise spatter
1969 Fathom Green
SS 350 Coupe
71 Impala Sport Coupe
Re: Spatter Paint
« Reply #21 on: November 19, 2007, 07:11:26 PM »
69's got aqua and dark gray.
Bjv69ss
Re: Spatter Paint
« Reply #22 on: November 20, 2007, 12:06:02 AM »
So, it would be correct to go with the color you like...
1969 Fathom Green
SS 350 Coupe
Flowjoe
Re: Spatter Paint
« Reply #23 on: February 07, 2008, 03:34:49 PM »
So is the "correct" paint water based like the rattle can stuff?  Was the factory spatter paint also water based? (it would seem so in some cars I've had that ended up with wet floors).
fireZ
Re: Spatter Paint
« Reply #24 on: February 08, 2008, 11:51:15 PM »
What kind of pressure gun do you shoot Larrys trunk paint with. A HVLP or a shotz gun.
1968 Z28 LA Built
LIC # RPO Z28
copo
Re: Spatter Paint
« Reply #25 on: February 09, 2008, 06:14:39 AM »
When I had my 69 trunk sprayed with Larrys paint, we tried to use HVLP paint gun but it kept plugging up the tip. We had to switch to a shotz gun. I can't remember what pressure we used. The shotz gun gave it a more original looking pattern then the paint gun did.
fireZ
Re: Spatter Paint
« Reply #26 on: February 09, 2008, 01:35:19 PM »
thanks for the help maybe someone else will have the pressure that I need to use.
1968 Z28 LA Built
LIC # RPO Z28
Brandan
  • 1969 Camaro SS 396 X-66 M22
    • 1969 Camaro 396 SS M22
Re: Spatter Paint
« Reply #27 on: February 11, 2008, 03:13:16 AM »
was there a difference from the 67's to 69"s or were they all the same?
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
911 Guy
Re: Spatter Paint
« Reply #28 on: January 25, 2024, 01:34:48 AM »
I'm going to guess on HVLP   Start w 2.0 Tip  16-18 lbs Air at Gun (Not Tip)
Paint ?  Read TDS for product spraying info, If nothing determine product type 1K or Solvent based.
mix accordingly, if no info start at 1:1 and I would then start removing reducer to thicken test sprays
or try to lessen Air Pressure.   Practice on a file cabinet or old inner fender to get spray technique
camaronut
Re: Spatter Paint
« Reply #29 on: January 29, 2024, 01:47:57 AM »
i saw a restorer shoot the trunk matte black then use the "flick the paintbrush" technique with aqua paint to simulate the aqua spatter.  Looked damn convincing to me. Getting the flat aqua interior wall paint (oops- sorry - did I say interior flat wall paint) the right viscosity is the key.  Use your finger (like you're flicking off a bug off your finger) at the ends of the paint loaded brush and "flick" the paint onto the surface. It takes practice, its tedious - but it looks awesome.  (They also flicked the entire brush too........)
