Author Topic: Muncie Shifter Stabilizer Bar  (Read 1842 times)
dannystarr
« on: October 25, 2021, 02:24:58 PM »
Has there ever been a offset shifter stabilizer bar found on a documented original small block 67-68 with a 4-speed Muncie?
 Danny
MO
Re: Muncie Shifter Stabilizer Bar
« Reply #1 on: October 25, 2021, 11:15:02 PM »
Is this what you are asking about?
dannystarr
« Reply #2 on: October 26, 2021, 03:34:36 AM »
Yes,
 All my cars have the correct straight rod. Just wondering if several or even one came on an original car. .. Danny
x66 714
« Reply #3 on: October 26, 2021, 11:31:58 AM »
Yes,
Are all of your cars LA Danny? I bought my LA 68 Z/28 in 1976. The shifter that was with it said to be from that car. It has the bent version but I can's say it's correct. I did some looking after you posted this. I will continue watching....Joe
dannystarr
« Reply #4 on: October 26, 2021, 03:53:17 PM »
VERY interesting point. By chance, every Camaro I own is a Norwood build. Maybe there was a difference between the two factories? The rubber does bind to the side slightly on straight bars. I was told that first design had an offset rod. But if true and it worked so well, why install thousands of straight rods after using the offset. Could be a fun research topic. Trying a big block one on a '68 Muncie shifter fits Perfect with NO rubber binding. So just wondering.  ... Danny
