Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Body Mount Components (Treating)
« previous
next »
Print
Pages: [
1
Author
Topic: Body Mount Components (Treating) (Read 3010 times)
gbowman
Member
on:
October 20, 2021, 02:59:09 PM »
Looking for suggestions on treatment of subframe body mount components, mainly the bolts and washers to prevent discoloration and particularly rusting. Is there anything readily available on the open market? Thanks.
Tweet
Logged
68 RS/SS 396
69 X11 SS
camaronut
Hero Member
Re: Body Mount Components (Treating)
Reply #1 on:
October 20, 2021, 04:10:12 PM »
A buddy of mine has a set of repro body mounts on his 69 SS. After four years on the car, they are starting to split / dry rot. Must be that great Taiwan / Chinese rubber.
Not sure if treating them with any rubber protectant will help.
Logged
Hero Member
Reply #2 on:
October 20, 2021, 07:06:22 PM »
"mainly the bolts and washers to prevent discoloration and particularly rusting"
I use Boeshield T9 out of a spray can found online or marine supply stores. This and other product work great on natural and plated parts.
https://boeshield.com/automotive-motorcycle/
Edit Part number and add link. (JFW) 10/20/2021
Last Edit: October 20, 2021, 08:23:17 PM by 169INDY
Logged
Hans L
Member
Reply #3 on:
October 20, 2021, 09:11:06 PM »
I use Boeshield as well. Last a fairly long and protects the surfaces from rust and corrosion. Once applied and dries, the piece looks clean and natural.
Logged
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
gbowman
Member
Reply #4 on:
October 21, 2021, 01:45:21 PM »
Any major prep work involved or just make sure the parts are clean prior to treating? Thanks.
Gary
Logged
68 RS/SS 396
69 X11 SS
Hero Member
Reply #5 on:
October 21, 2021, 06:33:58 PM »
How to use Boeshield T-9 in general?
For a heavy film; Put on T-9 and leave it on. T-9 will dry into a thick protective layer.
For a thin film; Put on and leave on for at least 2 hours so it can fully penetrate the metal. Afterwards wipe off the excess.
T-9 dries to a waxy waterproof finish without leaving a sticky film to attract dirt.
General cleanliness is beneficial when using this product.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
