Do you mean 8N429717 ?
The stamping on the trans is probably just as important as the tag. I know you won’t get a ratio code on a 68, but there are ways to tell if the gear set is original.
Tags are out there. So it’s not a definite indicator.
I would have to look at the A.I.M. to see which tag was being used at that assembly time.
