Author Topic: Ignition coil screw  (Read 2670 times)
rjprice
Ignition coil screw
« on: September 23, 2021, 01:33:07 AM »
I have a '69 L48 with cowl induction.  I was missing the screw for the coil bracket so I ordered one from a parts house ($7 for a screw).  When I got it it was too short.
I have a 270 coil and "a" leaning bracket.  Is there more than one leaning bracket?  is there more than 1 screw? i.e., doe thes leaning bracket get a different screw?
« Last Edit: September 23, 2021, 02:54:17 PM by bertfam »
camaronut
re: Ignition coil screw
« Reply #1 on: September 23, 2021, 11:02:58 AM »
I bet your using an aftermarket coil that may be a little too large?  Seen that many times.  If you had to spread the bracket apart to make the coil fit - then probably larger than original Delco.
« Last Edit: September 23, 2021, 02:54:44 PM by bertfam »
rjprice
« Reply #2 on: September 23, 2021, 01:23:19 PM »
It's a "270" coil I got off Ebay.  I can measure it.  Anyone know the standard diameter of the "270" coil? anyone know the length of the original leaning bracket screw also?
« Last Edit: September 23, 2021, 02:55:09 PM by bertfam »
Re: Ignition coil screw
« Reply #3 on: September 23, 2021, 02:56:51 PM »
I moved this thread from the research topic area since it's not related to the information requested in that particular thread.
« Reply #4 on: September 23, 2021, 03:33:17 PM »
GM Coils are appx. 2-1/8" (2.125") Nom.
GM Coil Screw 1-1/2" (1.500")Mon.
AMK Kit 10-24 X 1 1/2 SLOT ROUND CAD. 2 pk, B-10882
