Author Topic: Inspection cover - 403 bellhousing - one piece rear main seal?  (Read 2404 times)
DAVEN1256
Do they make a flywheel inspection cover that will work with a "403" bellhousing mated to a one piece rear main seal engine?
When I tried to install my original cover from the two piece seal engine on my new one piece, the cutout on the cover that goes around the crank seems to be hitting the housing of the one piece seal before you can push it all of the way up.
If they don't make a cover that works with this combination, are people trimming their original covers to fit around the one piece seal housing?
Thanks......Dave
Stingr69
Re: Inspection cover - 403 bellhousing - one piece rear main seal?
« Reply #1 on: June 29, 2021, 12:38:02 PM »
I don't think an off the shelf cover exists for the "403" with one piece rear main seal.  I do know there are none for the "621" bell housing with one piece rear main seal.
