Author Topic: Value of 1968 RS?SS When Changing Color  (Read 8769 times)
z281967cam
« on: June 18, 2021, 07:43:18 PM »
Current project is a 1968 RS/SS Big Block 325 HP  4 speed car with standard interior. The car has been repainted once before in a non Camaro Color. The original color was British Green code ZZ. How much of the value is affected if the car is repainted in a Camaro color that doesn't match the cowl tag. I am leaning towards putting the car back as it was born. However that British Green is not a color I would haver ever chosen when buying that car back when it was new. Just lThanks Mark
Z282NV
Re: Value of 1968 RS?SS When Changing Color
« Reply #1 on: June 18, 2021, 08:39:34 PM »
Mark, personally I think the value of the car will depend on the quality of the restoration rather than just the color alone. You are going to find more buyers looking for the more appealing colors like, black, blue and resale red but then there are others out there looking for originality as well. Here is a link to Camaros.net where the same question was posed for a Fathom Green 69 Z28. It's a good read with lots of opinions.
https://www.camaros.net/threads/decision-time-z28-paint-color-poll.412162/#post-3790418
Joe
69 Camaro
rich69rs
  • LF7/M35/Z22/Z87
« Reply #2 on: June 18, 2021, 09:39:43 PM »
Agree that you will find more buyers interested in the color of the car - and since the car is already “not original”, go with what you like.
My trim tag calls out Dover White - the car was restored in Glacier Blue.
Richard
Richard Thomas
1969 RS
z281967cam
« Reply #3 on: June 19, 2021, 06:56:38 PM »
Good read  and it helped me decide. I have another 1968 Camaro that I race in NHRA  Stock Eliminator. that is Ralley Creen and I like the waay the car looks. I will be going with the Ralley Green on the new project. Thanks for eveyones input.
camaronut
« Reply #4 on: June 20, 2021, 12:34:07 AM »
If it's a numbers matching car, then you'd be better served to paint it the original color.
If it's not numbers matching - paint it what ya want, and have fun.
68 Ragtop
« Reply #5 on: June 23, 2021, 06:09:40 PM »
Are you sure the original color was British Green? Whats the production date of your car?
x55cam
« Reply #6 on: July 09, 2021, 01:49:45 AM »
Richard
Glacier Blue is an awesome color , good choice.
Be careful about reading  health books. Some fine day you'll die of a misprint. - Markus Herz
z281967cam
« Reply #7 on: July 21, 2021, 07:36:41 PM »
upon further consideration and in preparation for the body shop I removed all the exterior trim and door panels and found some of the original color ZZ British Green under the moldings and door panels. I decided to repaint it in it's original color. The car was manufactured in January of 1968.  When I removed the tail lights and the fuel filler neck the rear panel was a semi gloss black finish. It's also going back that way. When i got the car the engine was missing, however all of the rest of the drivetrain is still with the car. I found a numbers correct 396 engine which is going into the car. Just a shame the original motor is gone.
Kelley W King
« Reply #8 on: July 21, 2021, 08:05:29 PM »
When I look at a car that does not have the original color my first thought is the cost to change it. Even if I don,t care for the original color. Just my 2 cents.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Vince
« Reply #9 on: July 21, 2021, 08:19:57 PM »
I'm glad you decided to have it painted the original factory color.  Whenever I am at a car show I will spend much more time looking at a car that has it's original color than one that has been repainted a non-original color.
68 Ragtop
« Reply #10 on: July 22, 2021, 01:48:29 PM »
British Green was popular that month as it was just introduced as a standard color. Before that Z could have been special paint which is why I asked the production date.
Numbers correct means different things to different people. It sounds like you found what I call a period correct engine. If it's close in date and a Camaro suffix on the pad, even better.
z281967cam
« Reply #11 on: July 22, 2021, 07:28:40 PM »
yes it is close to the date, unfortunely it came from a 1968 Chevelle with auto trans, I have the numbers matching Muncie transmission and Muncie shifter along with the matching 12 bolt I am not going to hide the numbers on the engine pad, it is what it is. I will make it as close as I can to the original production.
« Reply #12 on: July 22, 2021, 08:46:38 PM »
Cool, Green Jan 68 gets the White Hockey 68 style stripe?
68 Ragtop
« Reply #13 on: July 24, 2021, 08:33:37 PM »
Hockey stripe is a 69 only thing. 1968 D90 stripe is different. There is a pretty good explanation under Exterior here on CRG.
« Reply #14 on: July 24, 2021, 08:43:12 PM »
I used the wrong Term.
Re-stated.
"Cool, Green Jan 68 gets the White -Late 68 SS D90 Stripe"
,,,,,,That will look nice,,,,
JIM
