Author Topic: Dum Dum - Lower Quarter Panel to Tail Pan Corners  (Read 7949 times)
Re: Dum Dum - Lower Quarter Panel to Tail Pan Corners
« Reply #15 on: August 07, 2021, 01:23:21 PM »
Gray: AMK Products INC> Distr,  Mfr unknown.
(OPQ) ESB-M4G32-A SEALER
Permagum caulking.
5 X .19 D MASTIC BEADS ON 16' ROLL. 1 pk B-11608
I plan on using this on the foot well air ducts both sides. Found TONS of wadded up "GRAY" sealer between duct and body.
« Reply #16 on: August 07, 2021, 08:30:00 PM »
You can get the grey strip caulk at Tractor Supply, Home Depot or Lowes where the window seals and garage door seals are located.
« Reply #17 on: August 08, 2021, 03:56:22 AM »
I have some of the Mortite brand strip caulk; it isn't exactly the same as the original gray 3M strip caulk, but it's the closest I've found and it works similarly (I think it's a bit more beige than gray as the original was).   I do use the Mortite when I want as close as possible to the original 3M caulk.
« Reply #18 on: August 08, 2021, 03:57:01 PM »
You can take some activated Charcoal powder and knead it into the caulk to make it black.
« Reply #19 on: August 08, 2021, 06:14:27 PM »
Thanks for that tip.
I use carbon black for toner in some things myself.
