Author Topic: L78 M22 pacer - some firewall shots.  (Read 16353 times)
Re: L78 M22 pacer - some firewall shots.
« Reply #30 on: August 27, 2021, 11:33:13 PM »
Firewall and cowl going together...
« Reply #31 on: September 13, 2021, 10:55:56 PM »
Drivers Windshield header detail...
Original rad support dated 7th week.
Converted std watershields to DLX version with plastic "cups" for the DLX door handle releases
Building up the rad support with wiring, vacuum hoses, and HL washer hoses.
Pass side of rad support
Drivers side of rad support -- will be changing the HL harness plug to original brown ones.
Mated the subframe and the body up.
trans and floors.
70z28lt1
« Reply #32 on: September 15, 2021, 07:15:59 PM »
Is your fan on backwards??
« Reply #33 on: September 15, 2021, 09:47:35 PM »
It is, the engine trans sub frame assembly was delivered to me as pictured.
70z28lt1
« Reply #34 on: September 15, 2021, 11:51:21 PM »
That's funny!  Maybe even work better!  Hidden 5 HP.
Dusk Blue Z
« Reply #35 on: September 17, 2021, 01:47:49 PM »
Thanks for the detail pictures of the RS equipment on the core support. I'll reference those when I build out my Z10.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
« Reply #36 on: February 03, 2022, 03:07:55 PM »
More photos of the pacer -
I replated the shifter levers gold dichromate - The RS hoses are not all correct colors the actuator hose should be orange striped - so I changed it.
Striped the drive shaft -
NOALOX is what I use on all electrical connections and grounds.
The tail lamp housings are often distorted so I heat them in some boiling water then clamp them into position and set it with cold water.
