Author Topic: braided cloth split wiring sleeve  (Read 3794 times)
DAVID CHAMBERS
« on: June 03, 2021, 05:27:48 PM »
what is the correct size for my 69 Camaro engine wiring for the braided cloth split wiring sleeve. And where is the best place to buy it?
x66 714
Re: braided cloth split wiring sleeve
« Reply #1 on: June 03, 2021, 07:36:16 PM »
Where do you want to use it. I think the only place I've seen it is on the temp sender wire...Joe
DAVID CHAMBERS
« Reply #2 on: June 03, 2021, 08:20:50 PM »
Yes sir there and I would like to hide the new wires for the pertronix add on.
x66 714
« Reply #3 on: June 03, 2021, 09:16:45 PM »
NAPA used to have it. I don't know now. Asphalt coated cloth....Joe
« Reply #4 on: June 03, 2021, 09:46:37 PM »
I have Never known the Asphalt Cloth to be "Split", it is woven and does not hold shape when spilt axially. They do make a modern corrugated plastic tubing that is split.
Ebay, American Auto Wire and Local Swap meets are good sources for this item, I have had trouble sourcing locally & often get a blank stare at my Counter man when searching for the Gooey Cloth.
I this used in basically two places on the F Body: Temp Sender and the Start leads.
A friendly suggestion for hiding the pertronix lead would be to procure some Harness (NON ADHESIVE) Tapes and re-wrap or over wrap as needed.
DAVID CHAMBERS
« Reply #5 on: June 03, 2021, 09:59:05 PM »
Thanks for your help.
« Reply #6 on: June 03, 2021, 11:17:25 PM »
If you only need the asphalt cloth, HERE'S The Truck and Car Shop's offering (see below). Check out page 204, P/N 67-16701 for a whopping 4 bucks. Classic Industries probably carries it as well as most other vendors.
