Author Topic: 69 Z28 radial tires  (Read 12049 times)
Danzo
69 Z28 radial tires
« on: June 02, 2021, 10:27:51 PM »
Guys, looking to put a set of BFG Radial T/A's on a 69 Z28. going to use the stock 15x7's. What is the best tire size so there is no rubbing or any other BS. Stock suspension.
Thanks, Doc.
rich69rs
  • LF7/M35/Z22/Z87
Re: 69 Z28 radial tires
« Reply #1 on: June 02, 2021, 10:48:20 PM »
Might not help you very much since I have 14" rims on my '69 RS, but I have  BF Goodrich Radial T/A Tires; size P215/70 R14 on my ride.  They were installed in 2007 and have about 8500 miles on them now - no issues at all.
Richard Thomas
1969 RS
JohnF
« Reply #2 on: June 02, 2021, 11:23:57 PM »
P215/65/R15 is very close to the original E70-15
                   John
Gars68Tux
« Reply #3 on: June 02, 2021, 11:39:43 PM »
Yep, as mentioned, 215/65/15 is a popular choice if you want something similar to OE size.
Here's the spec sheet with dimensions. https://tiresize.com/tires/BFGoodrich/Radial-TA.htm
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
Hans L
« Reply #4 on: June 03, 2021, 04:02:32 AM »
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Stingr69
« Reply #5 on: June 03, 2021, 02:08:46 PM »
Good stock size recommendations here.
I know the more aggressive profile 245/60/15 will easily fit the rear but the front will rub slightly at the front fender extension.  If you are willing to grab a small part of the front edge of the extension with a pair of pliers and gently fold it in about half inch it will clear.  No paint damage or permanent modifications here.
If want zero contact you could run the 235/60/15.
« Reply #6 on: June 03, 2021, 02:34:53 PM »
Rally-Sports can have clearance issues at the left actuator bracket/shield.
« Reply #7 on: June 03, 2021, 04:01:59 PM »
Amen. I've got 15 X 7's on the Z11, were on the car when I brought it home, rubbed horribly. I run 215/60R15 B.F. goodrich T/A's on it now, reasonable tire width, no clearance issues whatsoever. I like them as they are not obviously tall tires, more comparable to the lower profile Wide Treads. They fill the wheel openoiing better than the stock 14 X 7 YJ's - plus they don't rub.
« Reply #8 on: June 03, 2021, 04:06:07 PM »
I've always wondered - what is different on the left side vs the right? I'd think that they were symmetrical.
« Reply #9 on: June 03, 2021, 04:28:57 PM »
Ackermann steering?
Back in the day it was common to see a hole worn in the left actuator cover. Could be we only noticed that on performance models with E70 & F70 tires. Those cars often had fast-ratio steering, which had 1º more angle at full lock than conventional steering.
« Reply #10 on: June 03, 2021, 05:00:47 PM »
But both sides would have 1º more angle...
Something was asymmetric, somewhere.
Vince
« Reply #11 on: June 03, 2021, 08:15:31 PM »
When I had 235/60/15 radials on my '69 RS Z28 with 15x7 rally wheels the left front tire rubbed on almost full lock left turns and/or on uneven surfaces, but the right front never rubbed as far as I knew anyway.  I eventually switched to E70 15 bias ply reproductions.   No problem with them rubbing.
« Reply #12 on: June 03, 2021, 08:26:04 PM »
I believe the Ackermann theory is that both wheels cannot pivot in the same arc.
Possible the uca mounts are positioned to accomplish that; the left side is slightly forward of the right. The extra 1º of angle on N44 cars [and 70 series tires] either creates the problem or makes it worse.
« Reply #13 on: June 04, 2021, 03:03:43 AM »
Yes, the inside and the outside front tires follow different radii. That's designed into the steering linkage. But there still should be symmetry.
Gars68Tux
« Reply #14 on: June 04, 2021, 07:25:12 AM »
The added weight of the driver (left side) ?  :):-\
Garth
