Author Topic: Caveat Emptor...tag swap?  (Read 4177 times)
« on: May 25, 2021, 01:38:27 PM »
https://www.ebay.com/itm/184854398970?hash=item2b0a2e47fa:g:m-wAAOSw639grKBy
124379N611211
From the ad:
This is a frame off rotisserie restored real X77 car with a numbers matching 302.
Body tag has been removed and re-installed. Looks real but does not indicate a vinyl top.
A Google search turns up pics and video of a silver & black Z/28. Same body tag, 350 engine.
Like to see the Protect-O-Plate. Not mentioned in the ad for the silver car.
http://www.2040-cars.com/chevrolet/camaro/1969-camaro-z28-real-x-77-factory-z-strong-350-4spd-12-bolt-very-nice-536862/
camaronut
Re: Caveat Emptor...tag swap?
« Reply #1 on: May 25, 2021, 04:00:48 PM »
Notice the map in the 2040-cars.con site.  It's in russian.  Interesting.
Danzo
« Reply #2 on: May 31, 2021, 12:09:02 AM »
Drivetrain stampings are in the link below, enjoy!!
Doc
https://www.duffys.com/details/used-1969-chevrolet-camaro/76267822
« Reply #3 on: May 31, 2021, 01:15:52 PM »
Block stamp [V0130DZ] does not match two other known originals.
N611211 was final-assembled on or about March 10, 1969. Other Z/28s built at that time have early March engines.
« Reply #4 on: May 31, 2021, 01:52:35 PM »
The machining decking marks are pretty obvious on the engine pad. It would be one thing if there was some light decking done to clean the surface and some of the prefix was still left behind, but there would be no raised edges around the fonts. The fact that there are raised edges around the stamped fonts clearly shows it was stamped after decking.
« Reply #5 on: June 01, 2021, 09:22:55 PM »
That block stamp its terrible. I agree you can see where extra machining was done, likely to remove a previous stamp, so they could restamp
« Reply #6 on: June 02, 2021, 02:12:13 AM »
Restamped block and trans. Axle looks OK. Tag looks reasonable.
