Author Topic: 1969 L78 Smog set up  (Read 4148 times)
Driveway_finds
« on: May 21, 2021, 03:19:42 AM »
I have a 1969 L78 I’m in the process of restoring. There’s a seller on eBay that is selling a complete “restored” set up. Has anybody had any luck with this one? Thanks!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
Check out driveway_finds on Instagram!
x66 714
Re: 1969 L78 Smog set up
« Reply #1 on: May 21, 2021, 03:29:58 AM »
Can you post the link?...Joe
Driveway_finds
« Reply #2 on: May 21, 2021, 04:33:16 AM »
Here’s the link, thanks!
https://www.ebay.com/itm/274777061021
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
buenymayor
« Reply #3 on: May 21, 2021, 07:17:25 AM »
Diverter valves are different between a SB and a BB. The difference is slight, but if you are going for a 100% correct restoration, you'll have to confirm with the seller which valve it has. IIRC, the SB valve is 29295, and the BB valve is 29297, but I'd confirm that with someone here. Pulley is probably a repop, but those are easy enough to change down the road.
« Reply #4 on: May 22, 2021, 03:41:05 PM »
Correct on the diverter valves. Years ago, ASL in Nevada had great, correct kits for not too far south of what this vendor is aksing. There are several choices here, including PartsPlace for a couple of hundred less. If you want to piece one together nowadsya, good luck - most of these parts like the correct restored pump and diverter will set you back some serious change if you can find them. Do yourself a favor and order an inoperative kit (devaned pump) and plug the exhaust tubes - it will be easier to tune, and get away from the inherent pump problems the cars always seemed to have.
Driveway_finds
« Reply #5 on: May 23, 2021, 04:15:25 AM »
Awesome thank you guys for the responses!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
WorkinProgress
« Reply #6 on: May 23, 2021, 05:52:08 PM »
The B/B bracket for the pump in the picture shows two holes in it on the bottom. As far as I know that is a newer bracket. I do not think any '69 Camaro had that bracket, but possibly end of year build got it.
        - Warren
