Author Topic: 69 Z28 Coil Springs. Is there a physical difference?  (Read 3635 times)
DarrenX33
« on: May 19, 2021, 12:38:54 AM »
I have been reading thru the posts trying to understand what type of spring is required for my car. Based on what I have calculated with the GM Spring Chart. I think my car, Z28, no special exhaust, no power steering, no spoilers, no RS would be a YF coded spring. Now the tricky part. Seems the Moog 6308s that everyone likes are not available. Springs in general seem to be hard to find. But I have a lead on an original used set. But I am trying to figure out how I would tell if they are the right ones for my car. So from the subject. Are there physical differences, markings other than the tags that would indicate which of the 3 options this used set might be?
1969 Z28 Rallye Green X33/M22/4.10
1972 Corvette
Re: 69 Z28 Coil Springs. Is there a physical difference?
« Reply #1 on: May 19, 2021, 12:44:52 AM »
Check out Detroit Spring.
« Reply #2 on: May 19, 2021, 01:19:07 AM »
What springs are in your car now?   and what are the issues with them?
DarrenX33
« Reply #3 on: May 19, 2021, 01:40:09 AM »
One of them is pretty bent. And they don’t seem to have the number of winds of an original set. So I think they are a replacement set. I would post a pic but I currently have no photo hosting.
1972 Corvette
