Author Topic: Control Arm & Parts Finishes  (Read 3685 times)
JohnDS
« on: May 06, 2021, 10:56:23 PM »
For '67-69...
Upper Control Arm- Painted with shaft attached? (ball joint installed afterwards)
Lower Control Arm- Painted prior to installing ball joint and bushings?
Dipped in black paint or sprayed?
Thanks!
Re: Control Arm & Parts Finishes
« Reply #1 on: May 26, 2021, 01:00:08 AM »
Dipped -
Upper - cross shaft and bushings, washers, and bolts installed prior to painting. Ball joint after.
Lower - I am not sure about the bushings however the balljoint was after paint.
Edgemontvillage
« Reply #2 on: May 26, 2021, 04:32:57 PM »
Lower Control Arm bushings were also installed after paint (dipping). Below is a photo of an original 10C built Norwood 1969 Z/28 with unpainted LCA bushings.
« Reply #3 on: May 31, 2021, 01:42:53 PM »
Thanks  LLoyd, great photo.
