Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Control Arm & Parts Finishes
« previous
next »
Print
Pages: [
1
Author
Topic: Control Arm & Parts Finishes (Read 3168 times)
JohnDS
Newbie
on:
May 06, 2021, 10:56:23 PM »
For '67-69...
Upper Control Arm- Painted with shaft attached? (ball joint installed afterwards)
Lower Control Arm- Painted prior to installing ball joint and bushings?
Dipped in black paint or sprayed?
Thanks!
Tweet
Logged
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Re: Control Arm & Parts Finishes
Reply #1 on:
May 26, 2021, 01:00:08 AM »
Dipped -
Upper - cross shaft and bushings, washers, and bolts installed prior to painting. Ball joint after.
Lower - I am not sure about the bushings however the balljoint was after paint.
Logged
Edgemontvillage
Hero Member
Reply #2 on:
May 26, 2021, 04:32:57 PM »
Lower Control Arm bushings were also installed after paint (dipping). Below is a photo of an original 10C built Norwood 1969 Z/28 with unpainted LCA bushings.
Logged
Lloyd
1969 RS Z/28 (Brooklyn Project) Link:
https://www.camaros.net/forums/133-build-projects/337897-1969-camaro-rs-z-28-brooklyn-project.html
Hero Member
Reply #3 on:
May 31, 2021, 01:42:53 PM »
Thanks LLoyd, great photo.
Logged
Print
Pages: [
1
« previous
next »
Restoration
