Author Topic: Is my 1968 Camaro an L34 or L35 motor  (Read 10573 times)
uscrichter
Re: Is my 1968 Camaro an L34 or L35 motor
« Reply #15 on: April 28, 2021, 08:31:48 PM »
I'm in the same boat with a July late July built '68 it has the 5500 tack with 4 speed and air that has a transplant motor and transmission, however it does have the original 3:55 rear end which according to the suggested power train groups should have been the  L-34, but it could have been ordered as an option for both L-35 and L-78, the last owner tore apart the head liner looking for a build sheet, never found one so unless I win the lottery when I get ready to restore and find one on the gas tank I may never know which engine it originally came with.
« Reply #16 on: April 28, 2021, 08:43:26 PM »
Higher chance it is NOT an L35. But you may never know. I assume you checked all of the other big block stuff?
« Last Edit: April 28, 2021, 09:21:31 PM by bcmiller »
uscrichter
« Reply #17 on: April 29, 2021, 10:21:35 PM »
Yes, heater core, proportion valve, master cylinder, power brake booster, exhaust system, fuel line, etc., addition to original paint on doors, blackout on rear deck and rocker panels(RS) car.
« Reply #18 on: April 29, 2021, 11:42:39 PM »
Crossmember, radiator?
Was the blackout on the rear panel original? Satin finish?
uscrichter
« Reply #19 on: April 30, 2021, 01:16:19 AM »
Yes, those all are big block items as well as the AC unit.
