1. Send your carb to Jerry.
2. The newer 3310 carbs are not the same as the original 3310. The newer 3310 carbs are a 4160 model (instead of the original 4150 model) with a primary metering block but a secondary metering plate. If you plan on using your original fuel lines, they won't fit (Some great info
HERE). Not only that, but your automatic choke won't work. The original 3878261-EH 3310 used a hot air choke and the later 3310's use a manual choke, or an electric.
3. Send your carb to Jerry, or find a good used 3878261-EH (3310) or aftermarket 3310-1 core and send it to Jerry if you don't care about the choke.
4. Buy a new reproduction 3923289-DZ.
5. Send your carb to Jerry.
