Author Topic: 1969 master cylinder, original or reproduction  (Read 4912 times)
x66 714
« on: April 06, 2021, 12:10:00 PM »
My original master cylinder got lost some years back. About 12 years back I purchased one on e-bay. It's the disc brake "US" type. Anything I can look at to determine if it's an original of a reproduction? Thank you, Joe
Re: 1969 master cylinder, original or reproduction
« Reply #1 on: April 06, 2021, 12:25:32 PM »
Compare the US stamp, from what I remember the U was not the same on the originals VS the reproductions.
If not mistaken it was Narrower and taller on the repro.
x66 714
« Reply #2 on: April 06, 2021, 12:26:43 PM »
Thank you. I'll have to find a known original to compare...Joe
« Reply #3 on: April 06, 2021, 12:46:10 PM »
I was under the impression that the reproduction castings all had the same 'cast date' on the side??
x66 714
« Reply #4 on: April 06, 2021, 12:58:23 PM »
I don't recall seeing a date code where it should be...Joe
jdv69z
  • 69 RS Z/28 52E
« Reply #5 on: April 06, 2021, 01:54:52 PM »
Here's mine. Oct 68 10B
Jimmy V.
« Reply #6 on: April 06, 2021, 02:08:46 PM »
The 'cast date' on a Delco MC is on the opposite side from the casting number, and it's in the form of a 'day of the year'...
Danzo
« Reply #7 on: April 06, 2021, 10:50:57 PM »
Joe, post some pics of what you got,
Doc
x66 714
« Reply #8 on: April 06, 2021, 11:30:56 PM »
Here's a few pictures. I might need to take it off as the camera flash makes it too much. Thank you, Joe
jdv69z
  • 69 RS Z/28 52E
« Reply #9 on: April 08, 2021, 01:29:43 PM »
Mine master looks like it's stamped directly on the cylinder casting, not a machined surface?
Jimmy V.
Stingr69
« Reply #10 on: April 08, 2021, 02:06:31 PM »
My original "US" master cylinder with a julian "239" date code for 239th day of '68 on a 10A build.
Stingr69
« Reply #11 on: April 08, 2021, 02:15:13 PM »
It was a machined pad originally but rust got to it.  Your stamp is consistent with mine and we are about 1 week apart.
