Author Topic: 68 Z28 Cowl Plenum fire wall pics  (Read 4300 times)
onekidbill
« on: April 06, 2021, 04:05:41 AM »
Looking for any pics of the fire wall hole for a cowl plenum air system. I’m restoring a 68 Z and it has a hole where it should be along with all the right screw holes. Just want to verify.
69 Camero Z/28
68 Camero Z/28
68 Camero RS
69 Corvette 350/350  2010 Camaro 2SS
Re: 68 Z28 Cowl Plenum fire wall pics
« Reply #1 on: April 06, 2021, 05:02:28 AM »
They were dealer or customer installed, I have seen one that had holes drilled across the area - and a couple which someone used a drill to out line the opening and then a chisel to break the connecting sliver. They came with a template, if you search for the cowl plenum template I am sure you will find a photo.
onekidbill
« Reply #2 on: April 06, 2021, 02:52:40 PM »
I’ll check it out. Thanks.
69 Camero Z/28
68 Camero Z/28
68 Camero RS
MO
« Reply #3 on: April 07, 2021, 01:43:39 AM »
onekidbill
« Reply #4 on: April 07, 2021, 04:58:36 AM »
Thanks. That’s just what I was looking for. 👍
69 Camero Z/28
68 Camero Z/28
68 Camero RS
