Author Topic: 1969 Camaro AD rally wheel question  (Read 2530 times)
suturb110
« on: March 26, 2021, 04:11:01 PM »
I have an early Van Nuys 1969 Z28 Camaro built 09D 1968.  Four of the wheels were clearly K 1 8 8 9.  In searching for a spare tire wheel I came across an AD wheel stamped K 1 8 8 19.  Does anybody know if the valve stem holes drilled before and after wheel date code stamping?  Attached are pictures.  Thanks, Mike
Re: 1969 Camaro AD rally wheel question
« Reply #1 on: March 26, 2021, 04:14:04 PM »
The piercing of the hole should have happened earlier in the process.
Not uncommon to see a digit missing in the valve stem hole.
« Reply #2 on: March 26, 2021, 04:16:48 PM »
The 8/19 wheel is also well within the parameters to have been in your car when it came off the assembly line.
