Author Topic: What the low down on this vin # really looking for about when it was built.  (Read 7269 times)
IVEGOTALL3
Hi Camaro Lovers, Could someone guide me on or about the time this Camaro was built? Vin # 12439N604551  have the body data I just would like to confirm it matches the VIN.
1969 SS 396 Camaro:1968 Butternut Camaro:1967 RS Granada Gold Camaro:1955 Chevy Truck X 2:1964 GMC SWB 4X4 Wide Side:1968 C-10 LWB Fleet side:1969 C-10 SWB Fleet Side:1972 C-10 SWB Fleet Side X 2
N604551 would have been final-assembled on or about Feb 25. Should have 02D tag date.
IVEGOTALL3
 :) This is what the Cowl tag shows'.  Thanks for the detective work.
Quote
Sure. As long as it's a factory tag! A lot are not.
And by the way, you're missing a digit in your VIN. It should be 124379N604551
IVEGOTALL3
I didn't want to make the detective work too easy.  The vin tag and cowl tag appears to be original from what I have noticed, but what do I know.
Post a picture of the tags and we'll be able to tell you more.
IVEGOTALL3
Here is what I have.  From what I have found it appears to be an L34 car.
Imo, looks legit.
Kelley W King
should be cortez silver, picture looks blue
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Is all of the original drivetrain there? What is the axle code?
IVEGOTALL3
I think the original running gear has been swapped out, here is a couple pics of the rear-end numbers.  I haven't researched it much.
Do you have the 2 letter code in front of the date?
IVEGOTALL3
I guess its below the u bolt. I'll have to get the car on a lift to pull it off, I'm way too big to climb under and unbolt it.
