Author Topic: AC Hose  (Read 3680 times)
hdptsr
AC Hose
« on: March 07, 2021, 06:10:00 AM »
What is the length of foam on 1969 Camaro AC hose, the hose from compressor to the Evaporator?  The protective foam as it goes over the alternator?  Do they sell a reproduction?
Re: AC Hose
« Reply #1 on: March 07, 2021, 02:36:50 PM »
Someone on here found a replacement foam from I believe a Mustang parts supplier - do a search under Power Steering hose - it also has foam over the top for a short length.
x66 714
Re: AC Hose
« Reply #2 on: March 07, 2021, 03:59:31 PM »
There are 2 pieces of foam on the main hose from the manifold to the POA valve. Mine measure 4-3/4 but they were most likely 5". From the bell on the manifold it's 18" to the first one. There is 6" between the 2. I purchased part number 15190971 GM from Ebay. Not possitive if it will work but it was cheap. Like 5 bucks. I can take pictures if you need....Joe
hdptsr
Re: AC Hose
« Reply #3 on: March 07, 2021, 04:34:57 PM »
Would something like this work for the accumulator hose insulation?
Aeroflex 3/4 pipe insulation
https://www.ebay.com/itm/Aeroflex-212-Ac11838-3-4-X-6-Ft-Pipe-Insulation-3-8-Wall/383968963855?hash=item5966556d0f:g:Jx4AAOSwctVgMWcT
Any pictures of original would be great!
Thanks Joe
x66 714
Re: AC Hose
« Reply #4 on: March 07, 2021, 05:04:15 PM »
Maybe but it looks too thick. The hose measure 1.66 diameter. Here's some pictures...Joe
Petes L48
Re: AC Hose
« Reply #5 on: March 07, 2021, 09:35:10 PM »
Maybe check a place like McMaster Carr to see if they have thinner wall insulation available, in a suitable foam material.
hdptsr
Re: AC Hose
« Reply #6 on: March 12, 2021, 07:52:09 AM »
