Author Topic: Help decoding 69 - Thanks.  (Read 7385 times)
427
« on: April 06, 2007, 01:40:37 AM »
I have recently purchase a 1969 Camaro with 427 engine.  Could someone help me with the codes and ID number below.
 vin #124379N527955
 Engine Block #3963512
 Head#3931063
Trim tag: ST-69   12437  NOR160376  BDY
              TR-10D  712  69B PNT
Any help will be really appreciated.
ggtsvnv
Re: Help decoding 69 - Thanks.
« Reply #1 on: April 06, 2007, 02:40:52 AM »
 The trim tag is ST-69 =1969  NOR = Norwood assembley plant 160376 body sequence number
                       10D = 4th week October build date TR 712 = black custom interior 69B= Cortez silver paint/w black vinyl top
427
« Reply #2 on: April 06, 2007, 05:42:16 PM »
Thanks for the help on the trim tag.  Hopefully someone will know something about the ID#.
ggtsvnv
« Reply #3 on: April 07, 2007, 01:14:11 AM »
  Your welcome sorry I cant be more help the VIN only tells what plant it came from N=Norwood and that it had a V8 from the factory. As for the block and heads I don't have a book that will tell me what the casting numbers go to. If you look on the block behind the altanatior (at least on small blocks) there is a pad that should have a stamp on it (something like T02VMC) followed by the last part of the VIN number to the car it was orgionaly installed in. If you can get those I can help a little more by telling you what kind of car/truck the engine was orgionaly installed in.
Camaro Billy
    • 1969 RS/SS
« Reply #4 on: April 07, 2007, 01:50:20 PM »
Colvin's Chevy by the numbers book shows the Engine casting number  application as a 1969 (mid year) 427 for Passenger,Corvette,Chevelle and Camaro.Also 1970 and 1971 454 applications.
The heads as 1969 - Passenger/427, Chevelle/396, Camaro/396, Corvette/427, and Chevy II / 396.
The casting date and pad stamp will help narrow it down.
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
