Author Topic: Sequence of firewall pad installation at steering column  (Read 2926 times)
vabeach56wagon
« on: March 02, 2021, 04:56:26 PM »
I am in the process of replacing the firewall pad and the steering column retainer, etc. What is the actual layer profile from the firewall back? Is it the 2 pc retainer and the rubber boot, then pad, then carpet, then carpet protection plate?
Two different cars I've been able to check differ. On one, a "restoration", shows the back of the pad through the firewall from the engine bay at the steering column. The other, a supposed original car, is foam, 2 piece plate, rubber boot, firewall pad, carpet, protection plate.
I've done a search and pored over the assembly manual...it may just be my creeping senility but I haven't found something to follow.
Thank you
paul
Re: Sequence of firewall pad installation at steering column
« Reply #1 on: March 02, 2021, 05:36:07 PM »
The foam seal for the base of the column goes up against the firewall -
The boot goes over then the carpet protector
vabeach56wagon
« Reply #2 on: March 03, 2021, 02:00:52 AM »
Thank you...immensely helpful.
