Author Topic: Distrubutor cleaning  (Read 3783 times)
john302
« on: February 28, 2021, 04:29:00 PM »
Restoring a distrubutor housing with slight corrosion . Has anyone ever cleaned corrosion from aluminum without blasting ?Dont want to remove the machine marks. Anyone ? thanks
Edgemontvillage
Re: Distrubutor cleaning
« Reply #1 on: February 28, 2021, 05:11:11 PM »
John, in addition to a multitude of chemical cleaners for aluminum, consider vapor blasting the housing, I've cleaned distributor housings with it several times and, unlike dry media blasting, it doesn't erode or degrade any of the machining marks or stamps. There is a thread on the subject of VB over on SYC if you're interested:
 https://www.yenko.net/forum/showthread.php?t=165437
Driveway_finds
« Reply #2 on: May 21, 2021, 04:45:02 AM »
I just got this one vapor blasted. Turned out pretty good!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
Check out driveway_finds on Instagram!
« Reply #3 on: May 21, 2021, 01:59:37 PM »
I have heard you can clean oxidized aluminum with MMO, but I have tried it myself.
« Reply #4 on: May 24, 2021, 03:06:50 PM »
Hi John, agree with Lloyd on what I've seen with vapor blasting even though I never personally used but I did utilize JohnZ's comment years ago using my blast cabinet to do some aluminum pieces with glass bead but at no more than 25PSI and it worked but a slow process.
« Reply #5 on: May 24, 2021, 06:50:34 PM »
Yes.   BEST Vapor Blast, BETTER L.P. Glass Bead, GOOD Eagle One Alum Wheel Cleaner and Nylon Brush,
Never(?): Wire Wheel, Dremel, Stainless steel wire brush,  Sandpaper, ETC.
I understand folks Might not need or warrant the BEST or BETTER  give the Non Blast attempts a try on a hidden area and see if your results are acceptable to you.
