Author Topic: Manual Trans Shifter Report  (Read 2683 times)
« on: February 28, 2021, 10:44:19 AM »
IIR, Bryon worked on the shifter report on main page. I reference this a lot. Thankful for the good and helpful info. Hats off to all who made this a concise informative report with many pictures.
However, there is a picture not in this report that I would greatly appreciate added. That would be a picture of the 1969 Hurst Shift Levers. I want to have a reference for the Muncie & Saginaw 4 speeds. And 3 speed Saginaw if different.
As an aside, I read somewhere that 3 speed floor shift 69s do not use the Hurst handle? If I am misinformed, I apologize. I’d like more info on the 3 speed floor shifter. I acquired a 3 speed shifter that the body has a single 3/8-16 bolt that holds it together. It had a bayonet exactly like the 4 speed Hurst which I robbed to repair my factory Hurst. Would like to know what that shifters application was for?
hihorse
Re: Manual Trans Shifter Report
« Reply #1 on: February 28, 2021, 12:09:09 PM »
Most likely the firebird. Strange, Camaro on its 3 spd shifters did not use the hurst Slip-in "bayonet" style round handle (stamped 5325) . i also purchased a 3 spd bayonet style shifter with hurst round bar , thought it was cool and different.
« Reply #2 on: March 01, 2021, 12:50:56 AM »
It's in the report.
>There is one basic shifter design used for the 1967-68 4-speed and 1967-69 3-speed shifters.
>1968 and 1969 Pontiac Firebirds used the same shifter as 69 Camaros and Firebirds also used a 3-speed version of the Hurst shifter.
