Author Topic: 68 rs z28 headlight bucket-dish. finish  (Read 4371 times)
Kaanderson
« on: February 27, 2021, 08:20:16 PM »
Hi, can someone tell me what the correct finish on the headlight buckets? The car has 1 painted black and one is a dull metal finish.  The repro ones are painted black. I would think the metal finish is correct. The car is a Feb build.
Thank you for your time
Re: 68 rs z28 headlight bucket-dish. finish
« Reply #1 on: February 28, 2021, 12:13:36 AM »
It is very possible the GM drawings allowed for both options for preservation, i.e. finishes; Paint or Plate. I have seen them both ways are take apart cars.
« Reply #2 on: February 28, 2021, 02:55:47 AM »
If it's the same for 67 then galvanized was the finish.
Kaanderson
« Reply #3 on: February 28, 2021, 12:34:44 PM »
Thank you
rare396bronze
« Reply #4 on: February 28, 2021, 07:40:43 PM »
My 68 is galvonized. Hope this helps.
« Reply #5 on: February 28, 2021, 08:24:32 PM »
1968 STD
Kaanderson
« Reply #6 on: February 28, 2021, 10:47:53 PM »
Thanks again everyone. I appreciate the help.
« Reply #7 on: March 01, 2021, 01:58:08 AM »
I've seen 4 head lamp cars with 2 galv on one pod and two black on the other.
« Reply #8 on: March 01, 2021, 03:09:27 AM »
I might have made a mistake, but not a big problem, Mine had a assumed "yellow dichromate" tint to the Galv spangled surface so I took the  easy way out and just Zinc Dichromate plated them (Restoration purposes) you loose the unique galv spangled appearance - compromise. Really when installed you do not see much of it.
I would assume, the sheets that these were stamped from were pre treated or they were hot dip galvanized after the fact.
My 68RS had one of each, but now that I think about it, It suffered a previous Owners girlfriend and a ditch and a line pole, so service bucket might have been installed (Black).
« Reply #9 on: March 03, 2021, 09:40:38 AM »
You can strip the gold off using evaporust or weak citric acid.
