Author Topic: Help with master cylinder cap  (Read 5649 times)
ReaperEd
« on: February 02, 2021, 03:52:05 AM »
Attached are photos of three. Are any of the three correct for 68 z28?
If not, a pic of a correct one would be helpful.
Thank you~
1968 Z/28 NOR 06B Original Drive Train
1973 RS Z/28 NOR 01B Supercharged Day 2
2013 ZL1 Lingenfelter
2015 Z/28
Re: Help with master cylinder cap
« Reply #1 on: February 02, 2021, 05:40:44 AM »
Here is Mine Fresh back from Plater.
1968 # 346 (code WT) cylinder with as built cap. 12D (LOS)
ReaperEd
« Reply #2 on: February 04, 2021, 04:25:52 PM »
Thank you, the one I have on the left appears the closest with the indented air relief holes.
Stay safe~
2015 Z/28
« Reply #3 on: February 04, 2021, 05:06:25 PM »
The one on the left looks like the one on my 71 LT1 and the same as on a 70 Corvette as well.
The one on the right I believe is a reproduction - the oem domes have a fillet at their base VS a distinct transition from a die edge.
I am going to assume the OEM 68 one doesn't have the brake fluid SAE J1703 spec on it - I don't remember whether the 69 one has the brake fluid spec on it.
ReaperEd
« Reply #4 on: February 09, 2021, 01:32:35 AM »
It does have that. You learn something everyday. Using the SAE J1703 as a search phrase I located a thread started by KurtS.
No I am correctly armed for the hunt.
Thank you ~
2015 Z/28
« Reply #5 on: February 09, 2021, 08:17:03 PM »
This is what you want for 68 and the one on ours.
2015-07-28 09.15.05
« Reply #6 on: February 10, 2021, 12:15:28 AM »
That's what I thought the 68 cap does not have the J1703 spec on it.
luv2sixty9
« Reply #7 on: February 10, 2021, 01:13:07 AM »
All three of yours are 69
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
