Author Topic: Rear bumper bracket rivets  (Read 28564 times)
x77-69z28
Re: Rear bumper bracket rivets
« Reply #15 on: December 27, 2013, 11:36:30 PM »
I used them during my 67 restoration. I took the bumper, bracket, and rivets to my friends machine shop. The bumper did fit in the press, and the whole job took 5 minutes. Looks factory. It does take a lot of pressure to crush them.
Buddy
68rs327conv
    • The build
« Reply #16 on: December 28, 2013, 02:59:28 AM »
I chiseled off the original rivets and cut threads off an old bolt and had it welded on to the original rivet head and secured with a nut.  That way if I ever want to re-chrome the bumper I can remove the bracket easily.  No one will know unless they reach up inside the bumper.
68 RS Conv 327/210hp, Powerglide Factory AC
joesauer
« Reply #17 on: December 28, 2013, 05:57:42 PM »
For those of you that used a carriage bolt with the head ground flat, what size (length & diam) stainless bolt did you use?
sbmiano
« Reply #18 on: December 29, 2013, 07:09:48 PM »
I bought mine from ricks and welded them on.  Worked great.
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
joesauer
« Reply #19 on: January 04, 2014, 12:36:51 AM »
Totally Stainless in Aspers, Pa. 1-717-677-8811 (totallystainless.com) sells a 5/16-24 x 0.7 flat top carriage bolt.  It's part number 2-0773 and is intended for Ford stepside rear fenders.  I ordered a few, & the dimensions are approx. 11/16 diam across the head, and 3/4 in. from the head to end of threads.  It's in their on line catalog.  Cost me all of .78/ea.
KevinW
« Reply #20 on: January 04, 2014, 01:25:58 PM »
I just went to Lowes/HD and looked through their selection until I found one that looked good, but I did not write down the size, sorry.
MyRed67
  • SZZLN 67
« Reply #21 on: January 05, 2014, 04:34:56 AM »
I wanted to rivet on the rear bumper bracket as original and bought the reproduction rivets. They did not work for me because the top of the rivet you peen over was too small in diameter, would not fill the hole after peening. I made up my own, plated them dark phosphate, and installed them with an air hammer using a long punch.
I used the rivets on my '67 bracket, and put a 1/4 in. flat washer on the small section of the rivet, then peened the end with air hammer and flat head attachment.  Worked great.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
m22mike
« Reply #22 on: January 07, 2014, 03:14:29 PM »
I have done the same washer trick several times also, this is the only way I know that works well to get them tight.
