Author Topic: Rear bumper bracket rivets  (Read 28557 times)
GaryL
  • Marilyn and me
« on: April 05, 2007, 01:49:39 AM »
Has anyone ever used these? I know they are sold, but has anyone ever installed them? How?
Gary
KevinW
Re: Rear bumper bracket rivets
« Reply #1 on: April 05, 2007, 11:36:00 AM »
I bought a set and could not figure them out.  What I did is take some stainless carriage bolts and cutdown the head so it matched the rivet shape. They look almost orig and wont rust and was a snap to put on!
othal
« Reply #2 on: April 05, 2007, 04:53:21 PM »
I have been looking for some rivets. Can you tell me where I can buy them?
Tinkerr
« Reply #3 on: April 05, 2007, 05:25:03 PM »
Rick's sells them (pg. 132 BU-72). I need a set, but am not quite sure if I can get the bumper and rivets in the press, so I've been holding off buying them. I still remember the difficulties with the rivets for the upper ball joints.
GaryL
  • Marilyn and me
« Reply #4 on: April 05, 2007, 05:31:12 PM »
I have not been able to find anyone that has set the rivets. I am going to thread the stud which is 1/4" and use a lock washer and nut I guess. It will look OK from the bottom. I am curious what JM does.
Gary
KevinW
« Reply #5 on: April 05, 2007, 11:46:11 PM »
I have a set of new rivets that I can let go cheap :)  Here are some pics of my bumper rivet lookalike project.  I used a nylon locknut and needle-nose pliers to hold the bolt during install.
Dave69x33
« Reply #6 on: April 07, 2007, 12:54:53 AM »
I had a set made based on the size of the rivets purchased from Rick's First Gen.  Like others have mentioned, I was not sure how would install them so I had a set made with threads as shown in the picture.  I painted them with OEM Paint brand black oxide paint.
The rivets I have seen on survivor cars appeared to be a dark phosphate plated but they may have tarnished over time so I am not exactly sure what finish they were originally.  I have seen very fine restorations with rivets that were silver Zink or cadmium planted.
Can any one confirm the correct original finish of the rivets for 1969 Camaros?
69er
« Reply #7 on: April 07, 2007, 01:18:31 AM »
Are the rivets being discussed the ones that attach the license plate bulb bracket to the
bumper itself?
69er
« Reply #8 on: April 07, 2007, 07:12:14 AM »
GaryL
  • Marilyn and me
« Reply #9 on: April 07, 2007, 12:45:11 PM »
Yes, 69er. The question is has anyone really used the rivets and how are they smashed?
Gary
zbo2
« Reply #10 on: April 08, 2007, 04:47:29 AM »
i have used them and they worked fine. i just put a dolly under the head of the rivet and used a large punch and hammer to crush the rivet. did it on the floor of my garage with the bumper very well protected.
m22mike
« Reply #11 on: April 09, 2007, 11:55:14 PM »
Did about the same thing, worked fine. I groud an old punch into a extra large center punch. Important to hold it square, get a helper. A good chance for you and the little women to spend some quality time together !
GaryL
  • Marilyn and me
« Reply #12 on: April 10, 2007, 04:04:19 AM »
I think that I could get someone to balance it on my vice and use a 1/2 rod to smash them.
Gary
tim68rsss
« Reply #13 on: April 18, 2007, 10:36:32 PM »
It took both my dad and me to install the rivets. Like stated above we took a ball-peen hammer and a couple punches and worked very slowly. I was very surprised how they turned out. Just take your time.
NoYenko
« Reply #14 on: December 24, 2013, 03:54:38 PM »
I wanted to rivet on the rear bumper bracket as original and bought the reproduction rivets. They did not work for me because the top of the rivet you peen over was too small in diameter, would not fill the hole after peening. I made up my own, plated them dark phosphate, and installed them with an air hammer using a long punch. Here is a drawing of the rivets for future use and a picture of them installed. My originals did not have rings on the head like reproductions do and were dark phosphate.
I did not have a picture of the original rivet peened area so I am not sure what it looked like. George
