Author Topic: Rear Brake Proportioning Valve Under Door - Date Code Question  (Read 17988 times)
camaronut
« on: January 27, 2021, 05:03:33 PM »
Does the rear proportioning valve that is under the drivers door follow the same dating convention as everything else?
In other words, would this valve be dated a month or so prior to the build date?
Wondering, because these valves weren't used on every Camaro produced, therefore they weren't produced in the same quantities as alternators, water pumps, etc.
So it would seem that you could have a valve dated a few months prior to being installed on a car, therefore the question arises?  Is it original to the car?
Maybe they were all blank, then date stamped before installation?
In other words, you'd have an 04A car with a valve dated 072-0.
Possible?  Inquirng minds need to know!!!!
« Last Edit: January 27, 2021, 05:29:38 PM by camaronut »
x66 714
Re: Rear Brake Proportioning Valve Under Door - Date Code Question
« Reply #1 on: January 27, 2021, 05:41:41 PM »
My original is 154-9, June 3rd. Car was built 8/29/1969 if that helps...Joe
camaronut
« Reply #2 on: January 27, 2021, 06:29:44 PM »
Interesting - almost 2-1/2 months difference.
Thanks Joe!
BTW, I mean't to say 072-9, not 072-0.  My bad.
« Last Edit: January 27, 2021, 07:07:45 PM by camaronut »
« Reply #3 on: January 28, 2021, 04:04:10 AM »
My LA car is 04A, NCRS production date is April 3, 1969 and proportioning valve is dated 052-9. That’s Feb 21.
« Reply #4 on: January 28, 2021, 04:26:26 AM »
My (Z11) LA car is 04C, NCRS production date is April 21, 1969 and proportioning valve is dated 050-9.
camaronut
« Reply #5 on: January 28, 2021, 04:04:48 PM »
At least we're consistant - but ony three cars / data points.
Anyone else???
copo
« Reply #6 on: January 28, 2021, 07:03:09 PM »
My car is NOR 06A, GM of Canada shipping date is June 24, 1969 and proportioning valve is dated 155-9.
uscrichter
« Reply #7 on: January 28, 2021, 09:02:05 PM »
I just checked mine, it's dated 128-9 and the car is 08C
« Reply #8 on: January 28, 2021, 09:47:26 PM »
My 09C Z28 (18 Sept 1969) has the proportioning valve:  KH   R   154 – 9   (3 June)
ie.   3 months prior to auto completion.
« Reply #9 on: January 28, 2021, 09:51:22 PM »
Most are dated pretty close to the car.
At least 2 of the cars listed were in the extended model year and they were using up old material.
camaronut
« Reply #10 on: January 29, 2021, 12:08:30 AM »
With all due respect, then it’s possible that a 06A car could have a 027-9 valve?
« Reply #11 on: January 29, 2021, 02:10:10 AM »
 Here are the following on my 67s
04B LOS- 75-7
05B NOR- 103-7
camaronut
« Reply #12 on: January 29, 2021, 01:15:01 PM »
Intersting results.
Looks like we may have stumbled onto something out of the ordinary in terms of conventional date coding / car build on this particular part.
Hopefully we can get Jerry to chime in.
67CruiseMaster
« Reply #13 on: January 29, 2021, 02:18:41 PM »
My 09C build 67 Camaro has a date code 229-6. August 17th of 1966.
67 Tuxedo Black Convertible.
camaronut
« Reply #14 on: January 29, 2021, 09:27:47 PM »
Then is it possible that a 06A car could have a 027-9 valve?  Being such a late build car?
