Author Topic: Replacing Lights for 68 instrument cluster  (Read 6026 times)
Butternut68
« on: January 12, 2021, 10:17:19 PM »
I decided I wanted to take out the instrument cluster to fix the bulbs since you can barely see the speedometer at night. Boy that was a mistake. Got new bulbs, put them back on the back of the cluster, and then more lights were out. I checked the circuit board, it seems to be fine. So I took a voltage tester (with the light inside the handle) to test and see if I even had power on the harness. I only have power on the wire labeled 7 on the harness. Figured I'd ask here if someone had some tips for me to track where it may be losing power. Thanks.
Edgemontvillage
Re: Replacing Lights for instrument cluster
« Reply #1 on: January 13, 2021, 12:08:10 AM »
You might consider re-posting in the Maintenance forum
Re: Replacing Lights for 68 instrument cluster
« Reply #2 on: January 13, 2021, 06:13:58 AM »
Moved post.
Butternut68
« Reply #3 on: January 14, 2021, 04:40:44 PM »
Good news, got everything working again.
x77-69z28
« Reply #4 on: January 14, 2021, 05:28:16 PM »
Tinkerr
« Reply #5 on: January 15, 2021, 04:03:42 AM »
Care to elaborate for others that may encounter a similar problem?
