Author Topic: Alternator bracket  (Read 4720 times)
rsr
Alternator bracket
« on: December 19, 2020, 02:33:10 PM »
 Was the upper alternator bracket used on 69 crossram set up a special crossram part only or did it come from the already existing GM parts supply? Also any pics or measurements anyone can provide? Thanks
camaroboy68ss
  • 1968 L30/M20
Re: Alternator bracket
« Reply #1 on: December 20, 2020, 02:46:49 AM »
Not sure off the top of my head, but looking at pictures its looks pretty closer to the outer bracket used on 67/68 Z/28's with their double upper bracket. Not sure if the bends would match up when flipping sides of the motor, but they mount in the same locations on the upper water pump bolt, but the 67/68 used a short pump where the 69 had the long and I cant recall if the boss is longer or farther out to make the bracket special.
Young gun with a Camaro or 2.
1968 Camaro RS L30/M20, 2017 Camaro SS
1968 Chevy C10 - Twin to the Camaro
1933 Ford Pickup - "Camaro in disguise"
rsr
« Reply #2 on: December 20, 2020, 03:55:31 PM »
Maybe but without a known original set up to compare it's just guessing ? Thanks
rsr
« Reply #3 on: December 20, 2020, 04:07:29 PM »
These appear to be different?
BRG Z28
« Reply #4 on: December 21, 2020, 11:08:26 PM »
I am pretty sure it is exclusive for a 1969 crossram.
rsr
« Reply #5 on: December 22, 2020, 05:48:52 PM »
Which bracket?
« Reply #6 on: December 29, 2020, 08:53:52 PM »
The one shown on the engine is the one I have seen the most.
