Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Fuel Sending Unit
« previous
next »
Print
Pages:
1
2
All
Author
Topic: Fuel Sending Unit (Read 13010 times)
Hero Member
Re: Fuel Sending Unit
Reply #15 on:
December 18, 2020, 05:30:30 AM »
Hook up VOM (Volt-Ohm-Meter) either: to the Brown (Tan) wire from Top of sender Other: to the ring terminal on the Black ground lead.
Set Ohm Meter to Resistance, R times 1 (Rx1)
I like to validate performance of the wiring at same time.
Logged
Hero Member
Reply #16 on:
December 18, 2020, 05:33:36 AM »
Float lowered.
Empty.
Nom Resistance: 0 ohms,
Logged
Hero Member
Reply #17 on:
December 18, 2020, 05:35:44 AM »
Float Mid Level.
1/2 Tank
Nom Resistance: 45 ohms,
Logged
Hero Member
Reply #18 on:
December 18, 2020, 05:39:43 AM »
Float Raised.
Full.
Nom Resistance: 90 ohms,
Theoretical Linear Tank curve, Actual Curve would be different.
Logged
Kelley W King
Hero Member
Reply #19 on:
December 18, 2020, 12:01:22 PM »
Jim, you might want to hang to the old Simpson multimeter. People might be collecting them soon. My comment about the full tank with gauge problems meant that the first thing I do when it does not seem to be working is put gas in it.
Logged
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Hero Member
Reply #20 on:
December 18, 2020, 04:52:12 PM »
LoL, The Simpson Series 260 is what I was trained on & am most comfortable with like an Old 4 speed.
I just wanted to add the "out of tank testing" reference for future searches and troubleshooting.
Logged
Henry Cloutier
Member
Reply #21 on:
December 19, 2020, 09:36:06 PM »
Thank you Jim,
I printed out your ohm/vs gauge chart for reference. Once the new sender is here I'll check it before install.
You guys Rock!!
Hank
Logged
Hero Member
Reply #22 on:
December 19, 2020, 11:25:16 PM »
You are Welcome.
I have a 68 that has been pegged (fuel gauge) for a year or so, just need to get it done myself (also)
JIM W
Logged
Henry Cloutier
Member
Reply #23 on:
February 03, 2021, 12:44:21 PM »
Hi everyone,
Just a quick update, the fuel quantity issue was in fact the sending unit. It has been replaced finally and gage is functioning correctly.
Thanks for all your assistance. As usual you all are right on!
Hank
Logged
Print
Pages:
1
2
All
« previous
next »
Maintenance
Fuel Sending Unit
