Author Topic: The correct starter  (Read 5461 times)
GIBSTER
The correct starter
« on: April 03, 2007, 02:34:11 AM »
I have a 69 350 engine 14" flywheel,  Checker auto and autozone show no difference in starter part numbers for the 350 and 327. They show it should be DL3664S. That doesn't work. The one for the 396 looked closer DL3560S. What starter should I be using?
        Darryl
camaromikey
Re: The correct starter
« Reply #1 on: April 03, 2007, 08:44:21 PM »
is it making a the standard grinding sound like it needs to be shimmed
GIBSTER
« Reply #2 on: April 04, 2007, 11:04:56 PM »
No. I had been using an old cast iron bell housing that the starter bolted into. I now am using the correct bell housing and needed a starter to bolt up to the block. By the way the one for the 396 with the staggered bolt holes worked.
