Welcome to the CRG Discussion Forum!Classified ads are not allowed on the forum.
Best way for storageA:up on stands with loose suspension with wheels off floor and if not WHY?B:or drive in and let it sit normally.Thanks in advance W
Make sure and start the car every week or two, and warm it to operating temp to keep the fluids circulated - acids are fond of forming in oil over the winter, plus you need the rust preventative in the coolant to circulate occasionally.
Quote from: z28z11 on November 19, 2020, 12:38:42 AMMake sure and start the car every week or two, and warm it to operating temp to keep the fluids circulated - acids are fond of forming in oil over the winter, plus you need the rust preventative in the coolant to circulate occasionally. I would NOT recommend starting a car like that. The acids form when the engine is running. Sitting, nothing happens. You won't get the engine and the exhaust up to temp to burn off the acids, so you are just adding to them. The coolant doesn't need to circulate, it's touching everything it needs to.Do museums start up their cars? No......
