Author Topic: Plate Beneath Rear Cocktail Shakers On 69 Camaro, Are They Original On Norwood  (Read 2825 times)
69RALLYSPORTZ28
Are these plates bolted to the trunk floor and beneath each of the rear cocktail shakers original GM on this X11D80 06A Norwood body?
Don't believe they are original.
67CruiseMaster
No, those ae not original. If you pull them up you would find rust underneath.
Scot
67 Tuxedo Black Convertible.
KevinW
The original shaker plate is spot welded underneath the trunk pan.
