Author Topic: 68 L78 deck stamp  (Read 5541 times)
Bucky L78
68 L78 deck stamp
« on: November 01, 2020, 02:15:59 AM »
Hi everyone
Im attaching some photos taken today while checking out a documented 68 l78 canadian sold camaro. I only have three examples of real MQ 68 stampings to go by, which are later 68 blocks, and I'm hoping there are more in the CRG data base.
My concern is the letter Q in the engine code stamp differs from the examples I have. The 840 heads with it are both cast the exact same day as the block (L77 Dec/07/67).
thanks Bucky
Re: 68 L78 deck stamp
« Reply #1 on: November 01, 2020, 04:42:17 AM »
I'm curious as to what camera/lens system was used to take those photos... ??
« Reply #2 on: November 01, 2020, 09:55:20 AM »
Share your concerns, but you’re in the right place to get the best advice from the very knowledgeable members here.
Are you the owner, or considering buying the car?
« Reply #3 on: November 02, 2020, 03:55:09 AM »
The Q appears to have the slight curve in the tail... it looks good to me.
« Reply #4 on: November 02, 2020, 07:46:35 PM »
I don't have a lot of stamps in that date range, but it looks reasonable.
Bucky L78
« Reply #5 on: November 03, 2020, 12:13:33 AM »
Here are the 3 that i have for reference that i believe are later dates, with a distinctively different "Q"
« Last Edit: November 07, 2020, 03:03:27 AM by KurtS »
« Reply #6 on: November 03, 2020, 03:01:09 AM »
Here’s a couple I have on file, cannot recall the source unfortunately. Didn’t post them previously, in case it influenced replies.
The April one looks to be the same pad as posted above.
« Last Edit: November 07, 2020, 03:03:40 AM by KurtS »
Maxsg1973
« Reply #7 on: November 03, 2020, 03:12:34 AM »
Here is one I have on file around the same date.
« Last Edit: November 24, 2020, 09:54:10 PM by KurtS »
Bucky L78
« Reply #8 on: November 03, 2020, 04:15:32 AM »
 Great,the T0404MQ block is one I used to own,it's since been reunited with the car a few years back. thanks for posting the pictures and all the responces.it seem there were two different Q's used.deepending on time of assembly,to  answer a few questions above I was  checking this car out for a friend, and he's paying up for the project , it's a documented canadian sold car,no problem there just wanted confirm on the different Q and make sure it is the born with motor, so it looks like it's a go, we'll load her up and bring it home . thanks again. Bucky
« Reply #9 on: November 03, 2020, 08:59:11 AM »
Look forward to hearing more, hopefully with photos, once you have picked the car up!
« Reply #10 on: November 07, 2020, 03:02:16 AM »
I edited out the pictures. I don't want this to be a depository of pictures available to restampers....
I don't like how it compares to the T0112MQ stamp.
Look closer  - the T0116MQ is a restamp. That pad has been decked.
