Author Topic: 1968 battery cables  (Read 3269 times)
steve's 68
1968 battery cables
« on: October 07, 2020, 12:33:31 AM »
after reading thru the threads relating to battery cables it appears that the 68 cables were top post, both black, and the small ground wire that goes to the fender is black, but I was unsure about the small positve wire to the junction block color, red or black?
thanks
steve
Re: 1968 battery cables
« Reply #1 on: October 07, 2020, 06:06:44 PM »
As far as I know it's a Brown fusible link to the junction box.
« Reply #2 on: October 10, 2020, 02:59:26 AM »
Steve, brown wire as James mentioned but without fusible link. A good source to review is lectric limited https://www.lectriclimited.com/vehiclesearch/result/index/year/109/make/21/model/48?cat=773
steve's 68
« Reply #3 on: October 10, 2020, 06:02:26 PM »
Thanks for the tips and clarification.  Steve
« Reply #4 on: October 11, 2020, 04:39:11 AM »
After checking a couple of the positive cables on the referenced page of Lectric Limited's site I found that the ones I checked have a brown wire with the imprint. - 14 gauge Fusible Link -
 or - Fuselink 14 ga.  - small white letters...
