Author Topic: Subframe marking  (Read 5181 times)
BillOhio
    • photobucket
Subframe marking
« on: September 28, 2020, 12:46:22 AM »
I am working on a 68 and the subframe and bottom of the car is coated in a waxy substance from the late 70s. Maybe ziebart?
I tried the hot water power washer today and it took most of it and the paint off and found this under the paint.  Could be a H.
Nothing too exciting but interesting
1968 RS 327 4 speed
Re: Subframe marking
« Reply #1 on: September 28, 2020, 03:18:25 AM »
Bill,
My front subframe had a yellow stenciled PN or date? very close to the same location ..
BillOhio
    • photobucket
« Reply #2 on: September 28, 2020, 12:38:56 PM »
I found a small lime green drop of paint on the top side but not sure where it came from.  That is all I found.  The wax substance was on so good it might have taken anything else off. Sad thing is, its all over the bottom of the car.  I might rent a steam power washer the next time if I can find one
1968 RS 327 4 speed
« Reply #3 on: September 28, 2020, 04:10:19 PM »
I found a similar "X" in yellow Also on my 69 LOS Pacer.
BillOhio
    • photobucket
« Reply #4 on: September 28, 2020, 10:04:00 PM »
Better shot.  Its interesting,  the welds on one side of this frame is a lot better than other side
1968 RS 327 4 speed
R68GTO
« Reply #5 on: September 28, 2020, 10:31:30 PM »
My interpretation of the mark is that it is two "X"'s.
BillOhio
    • photobucket
« Reply #6 on: September 29, 2020, 12:46:34 AM »
I can see that as 2 x's
1968 RS 327 4 speed
« Reply #7 on: September 29, 2020, 03:16:27 PM »
Which side is better than the other ? Reason I ask - my driver's side of the subframe was apparently "autographed" by the welder on the side of the subframe with "maybe" his/her initials, welded in place with the same appearance as the rest of the brackets, butts and overlaps. I would guess that more than one welder assembled frames, but I don't have a clue as to assembly protocols. Do we have a clue as to the subframe supplier ? Anyone else ever seen this ?
« Reply #8 on: September 29, 2020, 10:22:53 PM »
I found something like that on a 12C X66 I did 7 years ago yellow markings on the subframe pass side just in front of the front wheel centerline.
BillOhio
    • photobucket
« Reply #9 on: September 30, 2020, 02:15:48 AM »
My drivers side has a lot nicer welds.  Some of the slag was not even knocked off
1968 RS 327 4 speed
