Author Topic: 1967 with both RS and SS packages. What stays on the car?  (Read 10105 times)
trublucamaro
  • Go fast, go clean... just go!
« on: August 31, 2020, 12:22:07 AM »
So I searched the forums. I've poured over the options sheet and tried to decipher what a 67 SS/RS (RS/SS) would have come with as far as appearance items....
And by that I mean this... I understand what the RS package did to a Camaro, but if it was ALSO ordered as an SS, having the 350 due to being early in the production run, would the car have a louvered hood? Would you be able to get the bumblebee nose stripe? What badges would have been on a dual optioned car? "rs" on the front fenders? "ss"? How would the car have appeared when both packages were installed? Would the hood have been non-louvered due to it being an RS, or louvered because it was an SS. Would 350 badges been on it, or RS?
How would an early production dual packaged car appear?
(Maybe ED can offer some insight)
Thank you!
2017 2SS Hyper Metallic Blue
1967 Base V8, w/2-spd Powerglide
Re: 1967 with both RS and SS packages. What stays on the car?
« Reply #1 on: August 31, 2020, 12:36:44 AM »
My early 396 RS SS had a louvered hood and nose stripe. SS gas cap after 396 came out, SS 350 before. SS on front fenders.
trublucamaro
« Reply #2 on: August 31, 2020, 10:14:39 AM »
And your 396 SS is original? So you COULD get an SS car with the added RS package and it would
NOT take away the louvered hood (because it was an RS), the louvered hood stayed, and the fender badges went from "rs" to saying "SS"... is this correct?
What month was your 396 built? I'm assuming spring of '67?
67CruiseMaster
« Reply #3 on: August 31, 2020, 12:43:37 PM »
Maroman, did your car come with the stacks on the hood or fins? Fins were use in all SS cars in 67 as per this link http://www.camaros.org/exterior.shtml#SSHood. Stacks were use in 1968 if that is what you were referring to louvered hood.
67 Tuxedo Black Convertible.
x66 714
« Reply #4 on: August 31, 2020, 02:01:32 PM »
Your car should have everything a SS would've had in 1967. Hood with fins. SS fender emblems. SS350 grill emblem, SS350 gas cap. SS horn button. I don't know if it said SS350 (have to look). 350 fender emblems with lover emblem on rear part of front fender. SS was dominant over RS so nothing emblem wise would've been different. Nose stripe & I believe body side pinstripes also. Rally sport is of course hidden lights, solid tail lights with back up lights below. Special rocker & door lower trim. Hope I got all that correct...Joe
Petes L48
« Reply #5 on: August 31, 2020, 03:12:55 PM »
The SS 350 on the grille emblem and gas cap were on early cars, and phased out when the big blocks were introduced.  Depending which steering wheel was ordered, you may or may not have the center steering wheel emblem.
« Reply #6 on: August 31, 2020, 05:35:41 PM »
NOT take away the louvered hood (because it was an RS), the louvered hood stayed, and the fender badges went from "rs" to saying "SS"... is this correct?Yes, original 396 Automatic on the column, bench seat with custom interior. I know it since new. I'm thinking it was built in April, have to check.
x77-69z28
« Reply #7 on: September 01, 2020, 02:03:23 AM »
Basically, SS trumps RS.
MO
« Reply #8 on: September 01, 2020, 08:32:05 PM »
Body side pinstriping was included in the RS package.
Also worth noting is that the pinstripes were available with the Z21 Style Trim package.
« Last Edit: September 01, 2020, 10:05:15 PM by MO »
trublucamaro
« Reply #9 on: September 02, 2020, 09:01:51 AM »
Okay. All sounds good and what I was thinking. I had someone tell me that the hood of an SS/RS would have been smooth and not with the finned inserts (not sure exactly what you'd call them: louvered? Finned?) Anyway, I thought that was wrong. I figured you got the RS appearance items but will all the SS stuff replacing badging, etc... and then the SS hood.
Would the pin striping still have come on a car with the nose stripe? Or does addition of the nose stripe get rid of the pin striping it within the RS package?
(Thanks all for the input! Much appreciated)
« Reply #10 on: September 02, 2020, 11:20:56 AM »
You get both pinstripe and nose belt.
x66 714
« Reply #11 on: September 02, 2020, 11:21:59 AM »
I found this paragraph here....Joe
Optional Stripes
1967
Starting in April 67 and continuing through the end of the model year, the D91 stripe (aka front accent band) was available for non-SS, non-Z28 cars. Cars with the Rally Sport (RS) option had a gap in the D91 stripe (like the SS cars) for the RS emblems. On non-SS and non-RS cars, there was no gap in the stripe. Pinstriping was not available as an RPO, but was included with Style Trim or Rally Sport
« Reply #12 on: September 02, 2020, 01:10:10 PM »
MIGHT be my car when it was 2 or 3 months old. Says my JPG. is too big, don't know how to make it smaller.
x66 714
« Reply #13 on: September 02, 2020, 02:00:14 PM »
I sent you a PM...Joe
x66 714
« Reply #14 on: September 02, 2020, 02:52:41 PM »
Here's the picture maroman wanted to post. You can just barely see the pinstripes at the top of the front fender..Joe
