Author Topic: Decode 08 9 V on a CE stamped block  (Read 3098 times)
69RALLYSPORTZ28
« on: August 22, 2020, 12:43:29 AM »
Does 08 9 V on the machined surface on the bottom of the passenger side back corner indicate a Flint assembly date on a CE block?
The block is a 3970010 with a casting date of G 28 9
Re: Decode 08 9 V on a CE stamped block
« Reply #1 on: August 22, 2020, 01:54:54 AM »
Aug 1969 Assembly Date which does align with the casting date of July 28th 1969 Casting date.
"Starter" mounting pad.
JIM
Kelley W King
« Reply #2 on: August 22, 2020, 02:51:25 AM »
What does the V stand for? 5th week?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Coltdogg556
« Reply #3 on: August 22, 2020, 03:26:54 AM »
not 100%sure  but it looks like CE0 if I am right it was 1970.  The rest I just dont know.
My CE block in my 68Z  is CE9B  9 for 69, and I read  the B was for short block.
68 07C  Z28 UU, No Console,  No Tach with factory power steering. With 1968 Blip Top Cross Ram...
« Reply #4 on: August 22, 2020, 03:33:44 AM »
V on the oil pan rail surface would be for Flint V8 assembly. There are pictures of similar stampings in the CE thread here: http://www.camaros.org/forum/index.php?topic=12873.0;all
« Reply #5 on: August 22, 2020, 04:36:09 AM »
Per GM's letter, the 'B' represents the 3rd time thru the sequence numbers for that year's CE blocks... ie.   after the first pass, it goes to A..., then B...
