Author Topic: 1969 Camaro SS Factory A/C Control cable/switch  (Read 3826 times)
BryanK
« on: August 21, 2020, 10:01:03 PM »
I have a 1969 Camaro SS 396. The control cable farthest to the left on the dash controls the A/C compressor and the temperature. The slide with not go all the way to the top as if the cable is adjusted incorrectly or the A/C control module switch is bad. Where exactly is this switch, where the dash cable meets the switch, located??
WorkinProgress
Re: 1969 Camaro SS Factory A/C Control cable/switch
« Reply #1 on: August 21, 2020, 10:12:09 PM »
Didn't you already post this question? No need to repeat a new posting. Just post a new comment in your old post and it will bring it to the top again.
Not many B/B A/C Camaro's out there. You can check an assembly manual or unfortunately disassembly will be needed.
        - Warren
x66 714
« Reply #2 on: August 21, 2020, 10:41:39 PM »
Any 69 Camaro with a/c will have the same controls. The LH slide is the cable that opens & closes the door for the heater. If the slide won't go all the way up, there's a good chance you could have something stuck inside the box that's keeping the door from closing....Joe
JESSE TACKETT
« Reply #3 on: August 22, 2020, 03:18:47 AM »
Bryan, here's a pic of the switch, it's mounted behind the control panel and is worked by the left slider.
JESSE TACKETT
« Reply #4 on: August 22, 2020, 03:21:19 AM »
 this is the other end of the same left side slider cable. It is on top of the under dash box, you should be able to see this if you remove the glovebox.
JESSE TACKETT
« Reply #5 on: August 22, 2020, 03:23:06 AM »
This is the front of the factory control panel that came in our car.
