Author Topic: 1968 AM/FM Multiplex? What do I have?  (Read 4500 times)
Brent
« on: August 13, 2020, 06:53:06 PM »
I just bought a 1968 AM/FM radio with a "controller" that has volume, tone, balance, and front/rear knobs.
I know the U79 multiplex was normally installed in the center console door. And I understand that if a car did NOT have a console, there may have been a controller that mounts under the dash.
That said, I am unsure of what I have and whether it is complete (ie are there more parts needed to use actually use it).
I have read through all related posts and am still unsure what I exactly have.
I only wanted and AM/FM but got this controller too...
Brent
BRG Z28
Re: 1968 AM/FM Multiplex? What do I have?
« Reply #1 on: August 13, 2020, 07:41:27 PM »
68 multiplex for a car without a console.
plumL78
« Reply #2 on: August 13, 2020, 08:47:04 PM »
I would think it was from a 67 camaro because that is a 67 emblem
Brent
« Reply #3 on: August 13, 2020, 09:15:00 PM »
Thanks gents--I had never seen anything like this...and I thought I had seen every option...it came from a 68 RS and was original to that car.
I just wanted an AM/FM, I assume the radio is nothing special that is connected to the multiplex?  I can use it without the multiplex?
« Reply #4 on: August 14, 2020, 04:05:10 PM »
You can but need the plug to replace the cable.
« Reply #5 on: August 14, 2020, 08:12:54 PM »
Brent,
Tags still on the radio and/or multiplex body ? Number would pinpoint it -
rare396bronze
« Reply #6 on: August 15, 2020, 07:19:29 PM »
The bracket with Camaro name on it was used with a/c. One with out a/c used a different bracket. It show a good picture of  in the 68 assembly manual. Pretty cool item had a buddy that I worked give me a Nos one years ago.
Brent
« Reply #7 on: August 19, 2020, 09:07:36 PM »
So, the bracket is OEM? I have never seen one and thought it was an owner made bracket. But when I look at the rear, it appears to be factory..
rare396bronze
« Reply #8 on: August 20, 2020, 12:25:09 AM »
Yes it is factory for cars with a/c. Has a good picture in the 68 Assembly manual!
