Need to replace the turn signal switch on my 1968, 4 speed, floor shift coupe w/power steering. It's a 4th week of April 1968 Van Nuys build. I have not disassembled the steering wheel, etc. yet, as I wanted to order parts first for quicker repair. I assume I need an 8 pin turn signal switch assembly w/connectors, or a 9 pin with the steering column lamp stuff removed. Two questions: 1. I see references to the emergency flasher actuator hole being either round, D shaped, or O shaped. Any way to tell which without disassembly, and does it matter? 2. I see "Boyne" mentioned in reference to some steering columns but not sure what that means? Thanks.
