Author Topic: can I install ac vents into a non-ac dash.  (Read 2775 times)
Philayres
« on: August 04, 2020, 02:42:11 AM »
Hello
I have a 67 RS with the Vintage Air installed in a non ac car.  Works well but the little vents bolted under the dash bum me out.  Has anyone been able to install the stock ac vents into the steel dash?  Is there a document or template that would tell me what size hole I could cut in the steel then install the "ball type" vents?  the one in the center of the dash from vintage looks fine, I'd just like to change the left and right ones in the dash......
Thanks for your time!
Phil Ayres
67 RS/SS ZZ4 crate, 700r4
dale68z
Philayres
Re: can I install ac vents into a non-ac dash.
« Reply #2 on: August 05, 2020, 02:52:44 AM »
thank you Dale68z!
Phil Ayres
